Survey123 AI assistant (image analysis) works on web but not on mobile app
434
11-09-2025 07:26 PM
Bilguuntugs24
Hi everyone,
I’m currently using the Survey123 AI assistant feature for image analysis. It works perfectly when I use the survey in a web browser, but it doesn’t work at all on the Survey123 mobile app.
Has anyone else experienced this issue? Are there any settings, permissions, or configuration steps I need to check to make the AI assistant work properly on the mobile app?
Thank you in advance for your help!
2 Solutions
RossFindlayCOC
Not supported in the 3.x version of Survey123 Mobile App only the web form version. A new version is coming, but still a number of months away. Announcing the Next Generation of ArcGIS Survey123
Neal_t_k
MVP Regular Contributor
I was able to get this working in connect/field app using the common object detection model but it didn't transfer to the web app.  https://doc.arcgis.com/en/survey123/desktop/create-surveys/smartassistants.htm
Can you clarify what/how you are trying to implement?
Priya_Das
Hi @Bilguuntugs24
I believe the generative AI assistant in Survey123 is designed for the web designer and browser-based surveys.
https://doc.arcgis.com/en/survey123/get-started/survey123assistant.htm
RossFindlayCOC
Neal_t_k
