Survey123 add related record to existing feature
3034
7
02-24-2022 01:47 PM
DarrylKlassen1
Hello,
I have an existing feature service that has spatial data (buildings) and an inspections table related to it. I want to collect inspections against them using Survey123. Basically I would like to have a dropdown of all the building names - which would then find the globalid of that building - and populate the foreign key of the inspections so the relationship remains valid. I don't know how to do this in Survey123. I am able to populate my dropdown based on my feature layer using this in the appearance column:
autocomplete search("name?url=https://services1.arcgis.com/1acZBnEF9zjV0l5X/arcgis/rest/services/Test/FeatureServer/0")
But how do I populate my Foreign Key within the Survey in the related table automatically based on the building selection?
Thanks
DarrylKlassen1
@IsmaelChiviteI accomplished this using a piece of javascript and this in the calculation field:
pulldata("@javascript","get_globalid.js", "findCode", 'https://services1.arcgis.com/1acZBnEF9zjV0l5X/arcgis/rest/services/Building_Data_Test3/FeatureServer/0', string(${NAME}), 'GlobalID')
Thanks for your suggestion!
IsmaelChivite
Esri Notable Contributor
Have you considered using the Inbox for this?
Through the Inbox, you will be able to display (and filter) all buildings as a list and also as a map. Selecting a building from the list or map will open the survey for that building. Adding a new row into the buildings inspection repeat will automatically add your inspection as a related record.
DarrylKlassen1
Thanks @IsmaelChivite for the quick response.   I have never tried the Inbox before.  I don't really want to have the user select the building spatially, just from a drop down.   Do you have a link to any examples of how this can be done using an existing feature service and related tables?
DarrylKlassen1
Olwyn_Bruce
@DarrylKlassen1 , is there any way you could share the get_globalid.js code? I'm trying to do the *exact* same workflow! No worries if it's not possible.
DarrylKlassen1
Hi @Olwyn_Bruce , I have attached the code here:
 * JavaScript functions for Survey123
function findCode2(layerURL, userinput, field, token) {
	return "OUTVALUE";
function findCode(layerURL, userinput, field, token){
    // Output value. Initially set to an empty string (XLSForm null)
    let outValue = "";
    // Check to make sure both layerURL and location are provided
    if (layerURL == null || layerURL === "") {
        // The function can't go forward; exit with the empty value
    // Set up query parameters
    let f = "f=pjson";
    let where = "where=NAME="+"'"+userinput+"'";
    let outFields = `outFields=`+field;
    let returnGeometry = "returnGeometry=false";
    let parameters = [f, where, outFields, returnGeometry].join("&");
    if (token) {
        parameters = parameters + `&token=${token}`;
    let url = `${layerURL}/query?${parameters}`;
    // return url;
    // Create the request object
    let xhr = new XMLHttpRequest();
    // Make the request. Note the 3rd parameter, which makes this a synchronous request
    xhr.open("GET", url, false);
    xhr.send();
    let mylen = 0
    // Process the result
    // This an abbreviated version without being able to distinguish different types of errors
    if (xhr.status === 200) {
        let response = JSON.parse(xhr.responseText);
        if (!response.error) {
            if (response.features[0]) {
                outValue = response.features[0].attributes[field];
                mylen = 1
    return outValue;
ShaibalAhmed
This is pure gold. Thank you so much @DarrylKlassen1
Olwyn_Bruce
Brilliant thank you for saving me the time!! Much appreciated.
