Survey with existing Feature Service, existing Features, Repeat and select asset by map
149
2 weeks ago
AdrianMarsden2
Hi
I'm new to the world of 123.  I've got a task in mind that has this use-case
  • Existing Asset layer
  • Related table with survey questions
  • Repeat Surveys probably required
  • Inspector needs to be able to click on point on map using iOS or Android app to select the correct asset
  • No surveys required for new locations - all new locations added in the office
So far I've got a survey and on the Web version I can see the map, select a feature and edit it.  But that doesn't seem to work on the mobile apps.  Am I missing something?
What are your thoughts
cheers
ACM
HannesVogel
