Survey where the user assigns values to existing features based on a domain
134
02-22-2024 12:27 PM
DuboisLuke
Hi Everyone,
I am a city planner trying to create a survey (in the form of a game) for community members to assign a preferred land-use to specific census block geometries. I have already created the geometries I would like them to choose from and defined a field with a domain of choices. I have created a survey123 with connect and used linked content to link the webmap shown below.
How do I create a survey where the user would select a feature and then assign it a specific category based on the domain? Is this something do-able with Survey123, survey123 and experience builder together, or something else? Sorry, this is vague - but I'm starting from a limited background with the tool.
Thanks for your help!
abureaux
MVP Regular Contributor
You can either build the survey directly in Experience Builder with the "survey" widget, and then pass data along with that (Depending on your use-case that is super convenient), or you can use a custom URL scheme (You would set this up in the popup, and a URL would be available for the user to click).
