Survey Style
390
01-26-2022 01:20 AM
HelenCooper
Occasional Contributor III
Hi all,
I'm trying to style a survey in Connect123 (see screenshot below) to have a black background and a white font.   However, when I publish the survey, the white font seems to take but not the black background (see second screenshot below).  Any ideas what could be causing this?
Any suggestions as to where I'm going wrong gratefully received!
Many thanks,
Helen
jcarlson
MVP Esteemed Contributor
What's the context of the second picture? Is that a web form?
You might try accessing your form from the main Survey123 site and adjusting the style there.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
HelenCooper
Hi @jcarlson , yes the second picture is a web form with white text on a lovely white background!  Thanks for your suggestion, that worked.  I was worried that if I adjusted the style from the online site that it would be overridden next time I published it again from Survey123 Connect, but it seems to work, so that's a relief!
Thank you very much!
