Survey Stalls with "Updating service details" when publishing
652
09-13-2016 11:09 AM
TL2
Occasional Contributor III
I am linked to 2 portals from my Survey123 Connect, both federated with datastore.  I am able to publish successfully to the first one (stg) but the second portal (dev) I recently added will stall with "Updating service details" during publishing.  The folder is added to my second portal with proper naming convention and the feature service can be found in the fold but the form never gets loaded.
I assume I should not have issues pointing surveys to different locations.  I am able to created a hosted feature service from within my dev portal (the one giving me problems).
JamesTedrick
Esri Esteemed Contributor
Yes, the publishing process should be identical between the two portals.  You are publishing 2 identical copies of the same survey?  There aren't any differences in configuration between the portals? (for example, login process or self-signed certs)
