Survey releatet to feature layer
313
03-30-2021 06:13 AM
HrEngen
Hi.
I have a survey containing maintanse quetions. I have a feature layer and I would like the survey to be relatet to.
the survey have to be filled for each feature in the feature layer once every year.
How do I do that?
After this I have to make at project i workforce where each feature from the feature layer is a task and assign the task to a worker using an attibute from the layer.
DougBrowning
MVP Esteemed Contributor
Check out this post on how to relate the features.  Each inspection would be related to the main point.
https://community.esri.com/t5/arcgis-survey123-questions/mapping-with-survey123-within-a-polygon-or-...
Hope the helps
DougBrowning
Hope the helps
