Survey not sending if opened from Collector
2140
11
05-13-2019 08:55 AM
MatthewDriscoll
Is this a know issue?  A survey that I have a link for the team to open up through Collector (Version 18.0.2.0) after a line gets collected will not send.  It will send if they launch the Survey123 application from the desktop shortcut. This survey only gets used certain months of the year, it work just fine last year.  I currently have Version 3.3.64 installed on a Surface Pro (Windows).
Tags (1)
MatthewDriscoll
In my first reply in this thread is an example.  I used XLSForms to design my survey.  Check out ESRI Training, there are a lot of good classes.
John_Shell
Also, we may need to use this type of process because we are working with WSDOT, & DOC, and sometimes a third party vendor for homeless area cleanups. This is very useful information.
John
