Survey date Incorrect calculated
443
08-08-2022 03:07 AM
Kristofer
Hi All,
I am facing the unexpected problem on Date calculation. For the solution of date things I used the both platform Survey 123 connect (version 3.15.170) and Survey 123 Web. On the basis of survey I observed the following things:
Observation 1:
I have created and published a survey form using Survey 123 connect. I used the date time question in the form and make it default as now(). When I opened the survey in web, the time showing incorrect its almost 30 minutes ahead from the local time.
Observation 2:
I have created another form using Survey 123 web. same I used the date time question and make it default as submitting date and time. the survey time showing correct as the local time. but If I publish it, the date result shoeing incorrect same as scene 1 (time incorrect almost 30 mnts ahead from the local time)
Could you help me to resolve this problem.
Thanks & Regards,
Sunita
LaurenceTait
Occasional Contributor II
Can you add the following to you survey and tell us what result is:
typenamelabelcalculationbind::esri:fieldType
calculatewsdatetimeSample Date/Timenow()null
calculatewstimeTimeformat-date(${wsdatetime},'%H:%M')text
