Survey data structure updating
244
02-21-2023 07:42 AM
GrégoireCATINEAU
New Contributor III
Hello,
I have modified my table structure from Arcgis Online. I added a new field but it don't appear on Survey123 Connect. Is it possible to update the structure without create a new Survey Form ?
2 Solutions
GrégoireCATINEAU
New Contributor III
Thank you very much Rachel for your answer but it's don't work for me.
finally i am going to use ultimate solution : create a new survey and copy/paste from previous survey XLSForm.
RachaelMurtaugh
New Contributor III
I've had to do that as well when I tried to edit the survey with appended data in it. You should be able to save the old survey with a new name to copy it.
RachaelMurtaugh
New Contributor III
My experience is you can edit the survey in Survey 123 Connect and republish. That will add a new field. It might cause you to loose data, but it has worked for me in the past.
GrégoireCATINEAU
New Contributor III
RachaelMurtaugh
New Contributor III
GrégoireCATINEAU
New Contributor III
Thank You Racheal for your help.
Grégoire
