Survey 123 webhook power automate not showing any dynamic numeric fields to choose from
1060
12-31-2020 02:07 PM
CharlescobBailey
New Contributor III
Hi, I'm creating a flow in MS Power Automate (Flow) and it seems that every field in the table with a numeric data type is missing from the dynamic fields list. Every other field appears to be in there. I'm pretty sure I used number fields in previous flows - can anyone enlighten me on why this might be? Thanks, cob
CharlescobBailey
New Contributor III
I found out more about this if anyone needs - an expression must be used. Even then some fields it will not take and it blanks out the expression when you try to paste it. You can't type it in manually either. The only way i could get it to work is to find one that would work and edit the field name in the expression box. Real pain. Thanks, cob
