Survey 123 Web Designer vs Connect compatibility
1868
10-27-2019 07:25 PM
deleted-user-1sAsOmMajBua
New Contributor II
Just wondering if the Survey 123 Web Designer and Survey 123 Connect Application are fully compatible - that is, that surveys created in Connect Application can be edited in Web Designer (and the reverse).
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Leandra,
You can start authoring surveys in Survey123 Web Designer, publish them - then bring them into Survey123 Connect to edit/modify the survey, then re-publish the survey. The reverse workflow (e.g., from Survey123 Connect to Web Designer) is not supported.
Hope this helps,
DerekLaw
Hi Leandra,
Hope this helps,
New Contributor II
Thanks Derek,
                     I figured that might be the case. Just wanted to double check before I started developing forms!
AndreaNesdoly
Hi DerekLaw,
Any chance that the reverse workflow (e.g. from Survey123 Connect to Web Designer) is supported now? I want to edit transferred content in Survey123 web designer, or at least copy the original survey for edit capabilities online.
