Just wondering if the Survey 123 Web Designer and Survey 123 Connect Application are fully compatible - that is, that surveys created in Connect Application can be edited in Web Designer (and the reverse).
Solved! Go to Solution.
Hi Leandra,
You can start authoring surveys in Survey123 Web Designer, publish them - then bring them into Survey123 Connect to edit/modify the survey, then re-publish the survey. The reverse workflow (e.g., from Survey123 Connect to Web Designer) is not supported.
Hope this helps,
Hi Leandra,
Hope this helps,
Thanks Derek,
I figured that might be the case. Just wanted to double check before I started developing forms!
Hi DerekLaw,
Any chance that the reverse workflow (e.g. from Survey123 Connect to Web Designer) is supported now? I want to edit transferred content in Survey123 web designer, or at least copy the original survey for edit capabilities online.
