in my past Survey 123 forms i get a service and another service with _steakholder extension.
Todaj i created new survey form, but there is instead of _steakholder service service with extension _results?
Is this normal, just a rename, or is there something new?
Hi @mrobar,
The _stakeholder view that's automatically generated by the Survey123 website was renamed to the _results view in the Survey123 3.16 October Update. There wasn't any functionality change, it was only a rename. If you look at the What's New in Survey123 archive, you'll see the change noted under the 3.16 October Update.
-Barbara
Hi @mrobar,
-Barbara
