Survey 123 return a label value rather than name
9246
16
01-17-2017 10:40 AM
BrentKinal1
Occasional Contributor III
I am trying to create a customized instance name for completed surveys and would like to show a label value rather that the name value for a select_one field. Is there a way to either return the label value directly into instance_name properties in setting or to calculate it into a text field or note?
This question was asked previously here: https://community.esri.com/thread/179622 but no solution was given.
JamesTedrick
Esri Esteemed Contributor
Hi Andrew,
I was asking what application/web page the screenshot in your post above (Jan 4, 8:09 PT/11:09 ET) is from - the Survey123 website or another application
AndrewHargreaves2
Got it. All screenshots are from ArcGIS Online. That one you reference (Jan 4, 8:09 PT/11:09 ET) is the "data" tab of the hosted feature service produced by Survey123.
JamesTedrick
In that case you might want to register an https://ideas.arcgis.com to support HTML content in the table.
AndrewHargreaves2
RuthOla
New Contributor II
Can ESRI add the following appearance options to survey 123 similar to enko.to. This will be a lot helpful to display question with similar answer
JamesTedrick
Hi Ruth,
The Survey123 web app supports the label and list-nolabel appearances, though it uses the table-list appearance for the single-choice grid.
NicoleKwan
New Contributor II
Hi James,
The table-list appearance for the single-choice grid does not seem to work for survey connect. Also tried using field-list and label, list-nolabel to achieve similar single-choice grid layout and does not work
