Survey 123 Report Selected syntax
2365
10
10-15-2024 01:03 PM
AudraPayne1
This is my first time trying something like this in the 'summary section'. I need all locations, which have been selected out in the survey 123 website to show up on this map. I thought I got it to work but it doesn't seem to be working as I needed it to. Now I have changed my methods. I have attached a screenshot of what I currently have in the syntax.
Thank you in advance!
AudraPayne1
The feature service published has an inspection main component then a repeat 'Photos_SPB' which you can see I am calling out in my firs screenshot then a second repeat 'Photos' that you can see I am calling out in my second. My need here was to call out whatever inspection and repeat that was selected on my arcgis survey123 webpage in the data ribbon. I needed this map to show all the features I have selected. these codes have achieved this. I hope this helps others. Answered my own question after two weeks here are the results. When you have repeats you cannot have a summary section encompassing these repeats. I actually haven't found a solution similar to mine I just tried a bunch of syntaxes until I could make it work.
