Survey 123 Publish stuck on "Getting form information"
7079
18
01-22-2020 04:55 AM
AlexChen
On XLSForm spreadsheet, I have a "begin repeat" section for multiple entries of resemble questions.  There is a geopoint component in the "begin repeat" section. This can be published from Survey 123 to ArcGIS Online My Survey. Everything was fine. However, if I added one more component within the "begin repeat" section, publish failed.
The publish process was stuck at "Get form information".
XLSForm
publish fails
How can I get this working?
Tags (1)
DougBrowning
MVP Esteemed Contributor
Did you add a new field to a repeat?  There is a old bug that causes this.  Trick is to add a dummy field to the main form and then it will publish.  Then remove the dummy.
DougBrowning
Marco_AlejandroBonilla
Thanks! Super effective!
Taku_RiverTlingit
Hey Doug,
I have the same problem - I added two fields two a repeat and want to re-publish, but then it gets stuck on "Getting form information". What exactly do you mean with adding a dummy field? So basically adding also a question to the main survey, then re-publish, and then delete the field within the feature layer?
DougBrowning
What I usually do is add a hidden field called tempforbug outside of the repeat.
Publish
Delete temp field
Publish
Do not delete from the HFS otherwise Publish will fail,
Good to go.  Hope that helps.
Taku_RiverTlingit
Perfect. Doug. Thanks a lot for the clarification. Solved the problem for me
I added the temp field in the survey outside of the repeat, re-published, deleted the temp field, and re-published again. Now it should be fine to delete the temp field from the HFS, right?
DougBrowning
Do you mean it kept it?  I thought it deleted it. But I think you can.
AlbertoMillán
Thanks!!
by Anonymous User
Not applicable
Thank you for the solution.
Update: This bug and its fix still exists in Version 3.12.232
DougBrowning
It says it is fixed in the upcoming 3.13.
  • Fixed BUG-000113652 Republish hangs when you have added questions only to a repeat or nested repeat.
