Survey 123 Portal error code 11 (Web Site)
2888
15
06-11-2019 12:11 PM
by Anonymous User
Not applicable
Hi all,
I am using this link and https://survey123.arcgis.com/?portalUrl=https://gispublic.waterboards.ca.gov/portalhttps://survey123.arcgis.com/?portalUrl=https:%2F%2Fgispublic.waterboards.ca.gov%2Fportal%2F
I keep getting survey error code 11 (Not Found). I am not too sure why.
Any help us welcome.
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
The next release is planned for next week.
danbecker
I'm still getting this error, any updates?
We are on Enterprise 10.7, base deployment. Just trying to login to the s123 website using the same URL format:
https://survey123.arcgis.com/?portalUrl=https://our.portal.url/portal
I can see the s123 website in dev mode with the PortalURL showing in the header. I then click "Sign In" and am re-directed to the OAuth2 login page of our portal.
I supply valid credentials, then am redirected to the error code 11 page, survey does not exist.
JamesTedrick
Hi Dan,
Could I ask you to file an ticket with Esri Technical Support to diagnose exactly what is occurring with the login sequence?
danbecker
It was actually caused by CORS headers that I un-necessarily added to the /portal and /server sites in IIS. After removing those req. headers, the site worked normally.
TavisThomson
Dan,
I am currently running into this exact issue, could you give a little more detail to which CORS headers you removed or changed and where they existed in the  portal/server sites.
Thanks!
SeguimientoESRI
Having the same problem with the headers, how did I remove them? Thanks
