SURVEY 123 -Is there a way to have multiple numeric fields on the form, and the last one will sum/average/"Other math functions" the previous entries. Similarly if it's a percentage to assure the entries add up to 100%? Thanks in advance for any ideas
3051
02-10-2020 02:01 PM
petegillard
New Contributor III
Trying to average multiple numeric inputs on a Survey 123 form.
UriGilad_EsriAu
Sorry, try
(${first_field} + ${second_field}+ ${third_field}) div 3
UriGilad_EsriAu
Hi Pete,
You can do this only if you're using Survey123 Connect (not the web version).
1. Create another row for your summary record, for example 'summary_field'.
2. Insert your equation in the calculation field of 'summary_field'. For example, to calculate the average of three other fields:
For more examples and operators see:
Formulas—Survey123 for ArcGIS | Documentation
Hope this helps,
Uri
petegillard
New Contributor III
Hi, i keep getting this message when trying to update the form. Tried the field to calculate as 'calculate' or 'decimal' neither worked. the formula is in the 'calculation' field as written. am i missing something? thanks
UriGilad_EsriAu
Sorry, try
petegillard
New Contributor III
Thanks! that did it!
