Survey 123 integrated to Field Maps using URL can't be used offline
1285
10-13-2022 02:31 PM
Honey
Hey guys,
Here's my scenario. I have a feature layer in field maps that when you click one of the pop ups, it will take you to the survey forms. I have linked it using URL. I have created the offline maps in field maps.
Now our problem is we can't use the survey123 form offline. It always needs internet. Everytime a field worker click the URL it will take them to the survey123 app but it will require log in. Our survey area mostly doesn't have reception so this is a bit probematic for us.
Thanks in advance!
Honey
Thanks! I've just found out that the surveys weren't downloaded that's why it keeps on logging off.
DougBrowning
MVP Esteemed Contributor
It for sure works offline fine.  You did not post the actual URL you are using (which would help a lot) but my guess is you are using http and not the link to launch an app like this.
arcgis-survey123://?itemID=8b0b0a9ac80c41f49d2b79b9dfa&field:Office={Office}
Unless you mean the app opens but they are not logged in?  They do need to be logged in to get a form then it stays logged in for 2 weeks.  It will not stop you if offline.  You can even skip the login and still use the forms.
see this for more  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-web-form-url/ba-p/...
or https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm
Hope that helps
Honey
