Survey 123 Hyperlinks are not opening
2343
03-24-2021 09:35 AM
Danielle_Journey
Having trouble with hyperlinks not opening in a survey.  The hyperlink is in the "Hint" section of a question. This is happening across different browsers for all users who have tested the survey for me.  Current workaround is to have the user right click the hyperlink and open the document in a new tab/ window.  The document is shared publicly and is 266KB.
I downloaded the survey, opened the XLSForm and noticed this tags in the href: rel="noopener noreferrer".  If I delete that tag in the href and re-publish, it gets added back in there automatically.  Is this a bug, or am I doing something wrong?  Thanks!!
UriGilad_EsriAu
Hi @Danielle_Journey,
Would you be able to share the XLSForm? Or at least a cut down version of it with the problematic question?
gmcgwn
Hi all
Did you ever get this figured out? I seem to be experiencing a similar issue. I have a link in a label for one question in Survey123 Connect - works fine when published. I have another link in another question's label - nothing happens when clicked. I have tried moving it to the hint, same result. I have verified the html. The problematic question is of the "file" type.
Thanks!
SMH-Rio
Still experiencing the same issue with version 3.19.116. In fact, the problem seems to be with the 'file' type question, because the same html in the hint of a 'note' question works normally.
Danielle_Journey
Hi @UriGilad_EsriAu , here is the XLSForm.  Thank you for taking a look!
SMH-Rio
edit:
I carried out some more tests and realized that the bold text inside the <a> tag causes this problem in file type questions. I don't know if other types of formatting also cause this problem, however, removing/changing the <strong> location resolved the problem:
<p><a target="_blank" rel="noopener noreferrer" href="https://google.com">test 1</a></p> - it works
<p><a target="_blank" rel="noopener noreferrer" href="https://google.com"><strong>test 2</strong></a></p> - does not work
<p><strong><a target="_blank" rel="noopener noreferrer" href="https://google.com">test 3</a></strong></p> - it works
