Survey 123 geotrace symbology
451
04-28-2023 04:32 AM
GIS_Ecologist
Good afternoon,
I have created a Survey123 proformas from Survey123 Connect XLSForm. Part of the form collects bat flight path information. What I would like is the symbology of the layer to display as an arrow to display the direction of travel.
How to I symbolise this?
Kind regards,
Hector
IsmaelChivite
Esri Notable Contributor
@GIS_Ecologist
  • Use arrow symbology for the sketch geometry while the user is interactively entering the bat flight in the geotrace question: Not possible. You can style the line color and width , but cannot add an arrow at the end.
  • In the geotrace map, use arrows to display all bat flights previously entered: This is possible if you configure your geotrace question to use a custom web map. You will need to add to your web map the bat flights and use arrows for symbology.
GIS_Ecologist
Hi Ismael,
Thanks for the reply.
So there is no way to symbolise the direction of travel.
Seems the answer is that I will need a separate question to show direction of travel.
