Survey 123 error survey123 could not convert string to float:
253
02-04-2025 05:54 AM
JurgenRotteveel
I made a Survey in the latest version of Survey123 Connect and receive the following error when i analyze the Survey: ''survey123 valueerror could not convert string to float: '<openpyxl.worksheet.formula.arrayformula object at 0x0000026BE87B31D0>' '' .
I am able to publish the Survey but when i fill in a Survey on my phone and export it i get another error (see attachment).
How can i solve this problem?
Best regards, Jurgen Rotteveel
abureaux
MVP Frequent Contributor
Seconded needing the XLSX to analyze further.
Not sure if the issue is related to this just yet, but I will add that you should only use the bind::esri:fieldType and bind::type columns when absolutely needed. Ignore them otherwise. Off-hand, they are the only thing I would think that would cause a mismatch like that.
ToddW_stl
can you share your XLSX form (or at least the section) where you're doing the conversion?  my guess is that it either has something to do with a calculation, or a custom Esri field type (or both are out of sync).
abureaux
JurgenRotteveel
I indeed had used a bind::esri:fieldType , after removing it the Survey is working. I thought a bind::esri:fieldType was necessary for auto filling data from filling in Field maps attributes (in a popup) but after removing the Bind type it is still working and the Field maps data is automaticly filled in in the Survey. Thanks fot the solution!
