I have a Survey123 survey that has collected over 1000 responses from the public over the last month and I am seeing intermittent issues with the form, I keep seeing the error message "Failed to Submit." and under details it just says "-unable to complete operation." any help would be much appreciated. This is really not a very helpful error message. Not sure what to do with it.
Hi Josh,
There can be a number of causes for this error message; this is probably most easily addressed via Esri Support.
Yeah, I have a ticket in but have not heard anything yet. Was hoping someone might have some ideas in the meantime. Just tired of explaining how sorry I am that it doesn't work and that I don't know how to fix it yet.
You can get a jump start by creating a log file during submission. See Troubleshoot—Survey123 for ArcGIS | ArcGIS - you don't necessarily need an AppStudio console; turning on logging without a console selected (or the 'searching for consoles' circle still showing) will log to a file. Turn on logging and attempt to submit the data. Then you will need to retrieve the log file:
The log file should have the submission error towards the bottom of the file; depending on the exact error, there might be a more detailed message that explains what the issue is.
thanks, ill give this a go.
