Survey 123 - Edit a submitted Survey
4131
09-27-2016 09:49 AM
DanRodman
Can a user of Survey 123 edit or update a survey after it has been submitted?
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Dan,
FYI, Survey123 for ArcGIS v2.0 beta is now available. It supports editing existing survey data.
Survey123 for ArcGIS v 2.0 (Beta Available)
Hope this helps,
DerekLaw
Hi Dan,
Please see this FAQ help link: Frequently asked questions—Survey123 for ArcGIS | ArcGIS
(Can I modify an existing survey?)
Hope this helps,
DerekLaw
Hi Dan,
Hope this helps,
DougBrowning
MVP Esteemed Contributor
You can bring up and old one from the sent box, change, then resubmit.  That way you have a record of both.
PeterMacKenzie2
 from the 2017 S123 site:
Survey123 for ArcGIS 2.0 Beta Program is now open
"As of Survey123 2.0 editing functionality as described above will be limited to Surveys without repeats. We will not support editing attachments either in this first round. Editing surveys including repeats will come later in a 2.x update."
can someone confirm that this still not possible to retrieve a record from the Inbox and add attachments?
JamesTedrick
