Survey 123 connect Crashing on Start up (problem is Qt5Qml.dll)
314
06-04-2024 12:35 AM
JapanGold
Survey 123 connect keeps crashing on start up (windows 11), was working fine before. I tried reinstalling multiple times but nothing works. Below is the event crash log:
Faulting application name: Survey123Connect.exe, version: 3.19.116.0, time stamp: 0x65ea6746
Faulting module name: Qt5Qml.dll, version: 5.15.6.0, time stamp: 0x6124a525
Exception code: 0xc0000005
Fault offset: 0x000000000000fc82
Faulting process id: 0x0x6350
Faulting application start time: 0x0x1DAB65059B0CDE5
Faulting application path: C:\Program Files\WindowsApps\Esri.Survey123ConnectforArcGIS_3.19.116.0_x64__eytg3kh68c6a8\VFS\Profile\Applications\ArcGIS\Survey123Connect\Survey123Connect.exe
Faulting module path: C:\Program Files\WindowsApps\Esri.Survey123ConnectforArcGIS_3.19.116.0_x64__eytg3kh68c6a8\VFS\Profile\Applications\ArcGIS\Survey123Connect\Qt5Qml.dll
Report Id: 09b00093-bf28-4485-8f85-59595d565d1e
Faulting package full name: Esri.Survey123ConnectforArcGIS_3.19.116.0_x64__eytg3kh68c6a8
Faulting package-relative application ID: SURVEYOneTwoThreeCONNECT
Any idea how to fix this issue?
ColForbin
I am getting the same error after Windows updates were done last night and today.  Did you find a fix?
safrasramzee
Hi There,
I'm still getting this error, is there a solution to this please? any recommendation would be helpful.
ColForbin
It seems that on my computer there was an issue with installing some Windows updates.  After multiple reboots, the issue resolved itself.
