SURVEY 123 CONNCET FAILED TO PUBLISHED
289
02-18-2022 02:58 AM
Thaiwoolawal
New Contributor II
Hi, Am lawal and am new user
Pls I try to a survey on Arcgis portal and is showing failed to create folder initially I have published the survey on Argis online and it worked fined but on getting to my portal is showing me error
@Philip-Wilson kindly help
HuubZwart
Looks like the folder Survey-TRANSFORMER_INSPECTION_FORM already exists in your portal?
Also, be aware you're sharing a bunch of personal info including portal url, username etc) with that file. You may want to repost with only the relevant info from your log.
Thaiwoolawal
New Contributor II
Thanks I will Like to delete the post
