Summarizing values of a repeat does not work in the web form
112
12-07-2021 08:07 AM
KimberlyMcCallum
New Contributor III
Hi All,
I have a survey where the user may enter many records in a repeat. At the very end of the survey, prior to submission, I would like to include a summary note for the user to be able to quickly review some of their data without clicking back through the repeat. Do do this, I simply added a hidden field in the repeat where I concatenated the field I want to put in the summary with a comma and space for readability (concat(${uselocation_name}, ', ')). At the end, outside of the repeat, I added a summary calculation field (sum(${locationNameCalc})), where all the values are added together. This looks fine in Connect but when I publish the survey and test it, the summary note simply shows NaN. I have set the bind::esri:fieldType to null as I don't want to save this in my feature service.
Anyone have any insight into this?
DougBrowning
MVP Notable Contributor
Oh to join strings you want join().  sum is just for numbers that threw me off.  (The apps let you cheat with + but not the web.)
This page is your new bible  https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Hope that helps
DougBrowning
You need to also set the bind::type field to a number (int or decimal depending on data).  A calculation field does not know the type so you have to set it.
Hope that helps
KimberlyMcCallum
New Contributor III
Hi @DougBrowning ! Thank you for your speedy reply! The field that I want to include is a string and I was hoping to use the sum() function to concatenate across the repeat to create a nice text list. I tried setting the bind::type to string but that didn't work either. Any other thoughts? Thank you!
DougBrowning
Hope that helps
