I want to capture the username at specific times (Ex: when a user clicks a radio button) but it appears the username is always captured regardless of if its in a relavant based on a radio button. I also cant store it in a variable without it changing.
Any ideas?
thanks
It would be a little tricky and depends on what the end game/goal is, but it sounds like you could possibly do the following -
I keep getting invalid calculate error. Basically I have 3 fields in play:
-my select one called Request_Status which has 3 selection options
-my username type called user_status
-my hidden field that stores the username called user_storage
on the hidden field called user_storage I'm running the following calculate: if(${Request_Status}='In_Progress', once(${user_status}),")
when I save my excel sheet I get the error mentioned above
Hey Joe, looks like within your if statement you have a double quotation instead of two single quotes.
if(${Request_Status}='In_Progress', once(${user_status}),") that should be two of these ' together.
If think if you change that up, then you should start to see some data following...
Cheers!
Mike
Error no longer exists but in testing it appears that my new field (user_status) which holds the username is changing if I login as a different user. I know this because I set this field to text for the meantime for testing
