Some Repeats Not Showing for Some Users from Inbox
556
06-07-2024 11:12 AM
RobertAnderson3
MVP Regular Contributor
This one may be a bit of a long shot, but I had a user having issues this morning when they went to edit a Survey123 submission (opened via a URL from Power BI) that one of the 5 repeats did not load into their form to be able to edit.
When I tried with my test account (same permissions as the user) I had no issues with the repeats. I made extra sure it was the same record and everything. I noticed that the record that is not appearing for this user has a different EditDate than the other 4 which makes me think it got disconnected somehow, though the ParentGlobalID is the same.
I came across some posts talking about the limitation of the maxRecordCount when loading the Inbox such as here, does this still impact things when you have a query to only load some of the records to the Inbox? Would this at all have any impact on some users differently than others?
DougBrowning
MVP Esteemed Contributor
Just making sure you have query allowUpdates=true in the bind::esri:parameters column on the begin repeat line?
RobertAnderson3
I do yes.
It's been working for a while now with no issues (sometimes a select_one field is blank but I think that's just how I have a calculation set up, a separate problem to figure out)
They all load fine for me, I just wanted to put it out there after having a user with issues (they sent me screenshots so I trust it happened) to see if anyone else had encountered this before.
