Simple prepopulate survey123 field from URL not working
1505
03-02-2022 11:34 AM
by Anonymous User
Not applicable
Hello,
I cannot get  anything in Survey123 to prepopulate from a URL from AGOL (Collector or Field Maps).  It opens Survey123 but the field I need populated is blank.
I boiled it down to a very simple test and still cannot get it to populate.
This is my url:
arcgis-survey123://?itemID=7f0e5eb93d424c1ea532da3d684c6a75&field:plot={st-cty-plt}
The itemID is correct. It does open Survey123 from Field Maps. The name of the field and the name of the attribute {st-cty-plt} are also correct. see below:
From survey123:
From AGOL:
Has anybody else ran into this issue or have any suggestions?
I even tried: arcgis-survey123://?itemID=7f0e5eb93d424c1ea532da3d684c6a75&field:plot=doggy
to try to get it to auto populate 'doggy' into the plot field and it is still blank.
Thanks!
by Anonymous User
Not applicable
Okay figured it out.
My original URL scheme was correct.
I checked other forums and it really is an '&'
The problem is that it does not like "-" in st-cty-plt  even though that is what it says in the attribute table in ArcPro and on AGOL. When I used {st_cty_plt} it worked.
DerrickWestoby
Try this instead:
arcgis-survey123://?itemID=7f0e5eb93d424c1ea532da3d684c6a75?field:plot={st-cty-plt}
The first URL parameter needs to be preceded by a ?
Subsequent parameters should be preceded by a &
by Anonymous User
Not applicable
Wow, I can't believe I missed that. Thanks!
That seems like it should work and should fix my original issue. However, now when survey 123 opens up after I click the link, it is stuck in a loop where it shows it is downloading. The image below should really be a gif, just imagine it downloading form then thumbnail and form again and doesn't stop. Any ideas where to look?
Made a new survey to see if there was something wrong with the first one
arcgis-survey123://?itemID=65b123278c8142afbf58bf0b50c4bc36?field:plot={st-cty-plt}
st-cty-plt, itemID and field are correct.
by Anonymous User
Not applicable
