Signature image is getting clipped
1414
11
05-03-2017 08:26 AM
JamieKelly1
Not sure if this suddenly started happening at version 2.0.xxx of Survey 123, but I've just noticed that signature images are clipped in the submitted data.  Attached is a copy of one of MY signatures from the ArcGIS Online feature service.
Has there been a change to signatures?
JamesTedrick
Esri Esteemed Contributor
Hi Jaime,
We're aware of this issue; we are planning to address it in a future release of Survey123
ChristopherBowles
Any idea on when this fix will be made?  Collecting signatures is very important for our surveys.
JamesTedrick
Hi Chris,
This will be fixed in 2.3, which we are targeting for July after the User's Conference.
ChristopherBowles
Hi James - it appears that we still have the issue of clipping signatures in the new update (2.3.29).  The signatures are shifted to the upper left when we save the survey to drafts.  We are using iOS (iPhones and iPads) to collect the data.
JohnathanHasthorpe
Hi Christopher
This issue has been partially fixed in that signatures are not cropped on submission of a survey. However there is still a bug where the signatures are cropped on re-load (e.g. re-opening a survey from drafts or the sent box) and sending. We have a fix for this other issue and intend to make it available in the next release.
ChristopherBowles
HI Johnathan - it looks like this fix has not been pushed yet.  Can you confirm when the clipping upon saving will be fixed?
Chris
JamieKelly1
In the meantime, is there a way to install an older version of Survey123 on IOS (iphone)?  Or is there a work-around so that the signatures are not clipped when the survey is submitted?  We have an application that we are testing, but without the signature, it will not be a successful test.
JamesTedrick
Hi Jamie,
My apologies, there isn't a way to downgrade an application.
JohnathanHasthorpe
Hi Christopher - this issue has been fully addressed. Please provide details of what you are seeing, on what version of the app and on what device.
Thanks
John
