Showing the same survey a bit differently in two different places
103
3 weeks ago
K_Jueckstock
Hey all,
I am interested in displaying the same survey 123 within experience builder but slightly different. One button would take you to the whole survey with the last few categories expanded, the second button would take you to the whole survey with the first few categories folded and the last few expanded. Essentially, you would be able to access everything from both buttons, but the folding/expanding would be different based for ease of use.
Is this possible?
TylerGraham2
Since you'd be controlling the group/repeats appearance with compact, you would need to publish a second survey to the existing feature service. Then you would copy everything from the first xlsx file to the new one and adjust the appearance settings to match what you want that one to do.  That will get you to the goal of two different survey layouts but going to the same dataset.
