sequential numbering forms is missing in Survey123
773
11-06-2017 03:27 PM
Joao_LuisDoria1
Hello everyone,
I need to add a sequential numbering in my survey to have a historic profile of total nº of forms by different users.
Is it possible to have it in XLSForms? I f not can someone give a little help or tip?
Tanks.
BrandonArmstrong
Hi Joao,
Assuming that you were the creator of the survey, you should be able to view the number of surveys submitted by each ArcGIS Online authenticated submitter by using the Survey123 website (survey123.arcgis.com).  Once you are logged in here, after selecting the desired survey from 'My Surveys', you should be lead to the 'Overview' tab for the survey.  Here you will see several options that are related to the submitted surveys.  You can click on the 'Total Participants' circle graphic at the top, or look at the 'Top Participants' section at the bottom.  Let me know if these options provide you with the desired result.
Brandon
Joao_LuisDoria1
Hello, Brandon
I did try it but it is not that issue. I need to have the login name as
this SMA_JB_## ... something like this: username+GlobalID.
The fieldworker must be identified with his username and the number of the
record (GlobalID). How can I solve this?
In this case the Natural Park Ranger uses the name of his Park and his
name?s initials. When he found a injuried bird he must put a tag like this
in the box to deliver to the veterinary:
SMA_JB_3.
I send you a screensaver of the form for the desired field and the xlsform.
Thanks for your help.
JLDoria
Joao_LuisDoria1
Or maybe the command to do that still not exist in xlsform.
How about a widget to do that: for each user there is a auto-number field (1,2,3,4...)
Just an ideia.
