Select_one list will not show labels when a choice filter is added
210
09-23-2019 08:54 AM
DougBrowning
MVP Esteemed Contributor
I cannot figure out what is going on here.  I torn down the list to just 2 items and they work fine.
If I add in a simple choice filter it just show the radio with no text.  It even adjusts to the correct number of choices but never a label.
I do not think it is a label problem since they do show without a choice filter.
hidden AlwaysLookup AlwaysLookup "Y"
select_one SpeciesList SpeciesFound Species found at site always=${AlwaysLookup}
list_name name label image label::language1 woodyherb statecode nonnative always
SpeciesList SedgesRushes Sedges Rushes None Y
SpeciesList OtherHerbaceous Other Herbaceous None Y
Any ideas?
Thanks
DougBrowning
When I first tried to use select_one_external it kept saying my list was not found so I went with regular list.
I now remade the external_choices sheet and the choice_filter works for external.
Still will not work for a regular select_one so not sure what is going on.
