Select multiple based on previous select multiple
4320
03-29-2023 11:05 AM
julian_svcs
I would like to base a select_multiple based of a previous select_multiple. When I make selections in my first select_multiple, the second select_multiple must be updated with what is selected in my first select_multiple.
I am using ArcGIS Survey123 Connect.
Example 1:
Example 2:
Thanks for any help on this.
ZacharySutherby
Hello @julian_svcs
Placing ${select_some_options} in the calculation column of the select_from_list question I would expect to work. I've uploaded the XLSForm I used as a sample, is this what you are looking to do?
Thank you,
Zach
ZacharySutherby
Hello @julian_svcs
select_multiple stores it's values as a comma separated list so what you can do is place ${select_some_options} in the calculate column for the Select options selected above question and because it will receive the list from the previous question those same choices will be selected in the second list.
Thank you,
Zach
julian_svcs
Thanks for the reply @ZacharySutherby . I am glad to hear this is possible.
I am not quite sure where I must put what. I am pretty sure I am missing something somewhere.
This is my survey tab:
This is my choices tab:
ZacharySutherby
Hello @julian_svcs
Thank you,
Zach
julian_svcs
Thanks very much @ZacharySutherby. I followed your logic in the XLSForm and I have got it working.
