Hi All,
I'm new to Survey 123, I can't find a way to be able to select more than one day. For example, in the datasheets, we entered the various days you are in the field. Kind of like the same thing you do when you are booking a flight.
Hi @Jaileen91 it sounds like you would like to capture a date range, is that right? The date and dateTime question types in Survey123 allow you to record one discrete date (and time), which gets stored in a date/time field in the feature layer. If you're recording a range of consecutive days you could have two date questions in your survey - one for the start date and one for end date.
If you're using Connect, check out the Dates and Time in Survey123 blog post for some useful info; there's also a Dates and Times sample XLSForm available in Connect.
Best, Jim
