select all in option selection_multiple in Survey123
318
08-05-2021 01:50 PM
Jcordovafredes
Occasional Contributor II
It is possible that in select_multiple you can select all the options at once or give it a condition.
For example: we have a geography test, which asks
What countries are from Latin America?
1.Chile
2.Argentina
3.Brazil
4. Bolivia
5. Venezuela
6. Uruguay
7. Select all of the above
Select_multiple country Which countries are from Latin America?
I want to select number 7 to select all the previous ones, or in its defect indicate by means of a conditioner that I select everything.
I don't know if there is any method
JansenLyons
Occasional Contributor III
You can default a multiple choice to already show items as selected in the design tab, but in the scenario of a quiz this defeats the purpose of that function. I would suggest checking Survey123 Connect on the desktop, it has a wider range of functions and tools than regular Survvey123. If anyone else doesn't find a solution I would recommend putting this into the ideas page for Survey123 as a new feature you would like to see because I would like to see it as well. 😉
Hope this helps some, best regards,
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
Jcordovafredes
Thanks for the answer, as much as I look for some method, it seems that at least today it is impossible, I will publish that in ideas
José Córdova-Fredes
