Searched linked map in survey123
435
07-12-2021 08:30 AM
ZGutknecht
Is there a way to be able to search in the survey123 map based on the linked content?
ZacharySutherby
Hello @ZGutknecht
If possible would I be able to obtain a little bit more information on the full use case? Are you looking to search based on a layer within the web map that is linked to your survey?
Thank you,
Zach
Thank you,
Zach
ZGutknecht
That is correct.  In Survey I linked a parcel map and would like to be able to search based on the parcel ID.
ZacharySutherby
Hello @ZGutknecht
Thank you for confirming! Unfortunately Survey123 only supports using locators to search in the map. I've created an issue internally to enhance the map capabilities to use the feature/table search configured in a linked web map.
Please feel free to log an idea in the ArcGIS Ideas page and/or log a case with Esri Technical Support and they will be able to log an official Enhancement to support the workflow.
Thank you,
Zach
Thank you,
Zach
