Hey ArcGIS Survey123 Team,
We noticed a recent issue with Pages and Select One Grids- it appears if pages are enabled select one grids completely disappear from the survey.
Is this a Bug or expected behavior?
Amanda
Hi Amanda,
Yes, what you are seeing is expected behavior with the interaction of pages and single-choice grids. While the appearance in the XLS file is table-list, it actually gets transformed into the same appearance as a page (field-list) in the background when rendering a form, leading to a potential confusion point in rendering the form.
Hi James Tedrick,
Good to know- is this somewhere in the documentation?
I noticed that once I published the form from connect to the Web, the single choice grid did show up- it was just in the connect designer that it completely disappeared. Is this still part of the expected behavior? If the goal is WYSIWYG then this is confusing behavior.
Thanks.
Hi Amanda,
This is listed as a bug (BUG-000130821) that we intend to address; as you point out with the web form, it is possible to have them co-exist; there needs to be an improvement in the processing logic of groups as pages.
