S123 repeat always starts minimal after satisfying relevant
3750
6
05-17-2021 01:21 PM
LarryWiebe
Hi All, @PhilipWilson (similar questions)
I have a survey defined with a setting of pages, then a repeat with an appearance or field-list and a relevant case that is not met until the user makes a select on the first page of the survey.
When the user fills out the data to make the repeat relevant, the repeat always starts in minimal mode, I would like it to start as it would is the appearance had no value (expanded) as I present the user several options on the screen that they are required to select at least one.
I have tried putting the repeat (no appearance) in a group (field-list) with the same results.  I am looking for a way to not have the repeat minimal when it becomes relevant.
I have attached a sample, remove the relevant statements to see the differences.
Larry
4 Solutions
DougBrowning
MVP Esteemed Contributor
Do you mean like this?  Then no I have found no way for it to start with 1 record.  When anything is not relevant it is '' so this makes sense really.
What you can do though is try the new visible column (body::esri:visible) to hide things.  I think that works since then it is just hiding the fields and not using relevant.  Just tested it on a simple one and it works.  Note this could then create a empty record when you do not want it to so test it.
Hope that helps
LarryWiebe
Thanks Doug, I was able to get the behavior I wanted using the body::esri:visible.  I always require at least one entry in the repeat so it works out perfect.  Thanks Again!
emilperlt_rrc
Hey @Anonymous User
Is there any way to change this?
I'd like to use repeats that have no record by default when the aren't relevant. However, when they become relevant it would be preferred for them to expand automatically so that users are forced to enter values in required fields within the repeat. Otherwise, a user can bypass the required fields if they don't hit "+" when the repeat becomes relevant.
Emil
by Anonymous User
Not applicable
HI @emilperlt_rrc,
No, it is not possible to change this behaviour. If you want the user to complete required fields in the repeat, you could set up a constraint on a note question or similar, so that a warning appears to say that you must complete the repeat section, by using a count of the repeats and setting the constraint to being >1.
Regards,
Phil.
DougBrowning
Hope that helps
LarryWiebe
by Anonymous User
Not applicable
Hi @LarryWiebe,
What you are seeing is correct, if a repeat is not relevant and changes state, there will be no record created, as per Doug's comments this is expected, as non-relevant questions can not have values.
Regards,
Phil.
emilperlt_rrc
Hey @Anonymous User
Emil
by Anonymous User
Not applicable
HI @emilperlt_rrc,
Regards,
Phil.
emilperlt_rrc
@Anonymous User,
Thanks for the quick response and suggestion!
Emil
