Returning The Label Instead of the Name Within Power Automate
1019
03-08-2021 07:37 AM
DaveK
Hello!
I'm using Power Automate to auto send emails to users with survey information once submitted. When select one fields are returned, they are returned with the Name, which are codes and not the label, which are the full name aliases. Is there any way to return the label field with the aliases instead of the name field which displays our codes?
Thanks.
DaveK
@JamesTedrick, Would you happen to have any information on this?
Thanks!
RickeyFight
MVP Regular Contributor
@DaveK Did you ever get a solution to this?
It was working correctly until recently.
JamesChan1
Hello DaveK,
Did you ever find a solution?  I am having the same exact issue with Select One questions returning the Name instead of the Label in Outlook send email v2.  My workaround would be to change the Name to match the Label on all my items...but I rather not use that workaround.
Thank you,
CCGIS
Hi @DaveK,
Did you ever figure this one out? I am using a select multiple but getting the text similar to Remove_this_Underscore and I would like to bring the labels instead.
