Restore a backup in Survey123
1564
06-17-2019 07:32 PM
by Anonymous User
Not applicable
Hi community!!!
I was recently assigned some forms to insert new variables; before publishing my new surveys, I made a backup copy of each of these forms and info. However, now I want to restore some of these backups and continue using the same URL with this survey.
Does anyone know how to do this? Thank you!
#Survey123 restore data survey123‌
Ismael Chivite
James Tedrick
Jim Moore
JamesTedrick
Esri Esteemed Contributor
Hi Pedro,
By a backup, did you create a new item in ArcGIS Online or a copy in Survey123 Connect?  Either way, the 'backup' procedure would consist of replacing the current XLS form with the backup XLS form and republishing.  Note that this only restores the form layout, not the data that has been collected.
by Anonymous User
Not applicable
Thanks James for your soon answer,
The idea is to restore the original XLS and  the data that had been collected, and continue using this Form.
Thanks!
JamesTedrick
Regarding the data, did you create a copy of the feature service?  If so, I would suggest using submission_url to set the backup as the 'main' feature service.  See Use Survey123 with existing feature services—Survey123 for ArcGIS | ArcGIS
