Required field only when survey opened from inbox
740
01-05-2022 06:28 AM
GaryBowles1
Is it possible to make a field required only when the survey is opened from the Inbox?
Inspection will be performed and any deficiencies that are not immediately fixed onsite, are tagged and repaired at a future date. When the repair is completed, the repair info will be added to the existing inspection form (open/edit from Inbox) and I would like to make the repair date required only when the form is opened from the Inbox.
--gary
Tags (3)
GaryBowles1
Thanks Doug that looks like it will work. I will test and see.
--gary
DougBrowning
MVP Esteemed Contributor
I think this  https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepopulateanswers.htm
pulldata("@property", 'status')
Returns draft, submitted, sent, or inbox if the survey was opened from Drafts, Outbox, Sent, or Inbox, respectively. An empty string is returned if the response is new.
Hope that helps
GaryBowles1
--gary
