Reports: Greater than?
297
06-17-2025 12:54 PM
AlfredBaldenweck
MVP Regular Contributor
I'm sure this is easy, but I'm in a rush so I'd figure I'd ask here.
How do you compare values in a report?
I want to rotate portrait photos.
This is not a valid expression, apparently.
${if genphotos.genimage | getValue: “width” < genphotos.genimage | getValue: “height”}${genphotos.genimage | size: 0:0:0:300 | rotate: 90}
Also, it doesn't tell me that it's invalid until it comes time to print, so...
Thanks!
AlfredBaldenweck
It was totally the parentheses. I've been fighting to get this survey to work at all all day so I kind of panicked when I finally got to the report step and it failed.
Correct syntax:
${if (genphotos.genimage | getValue: “width”) < (genphotos.genimage | getValue: “height”)}${genphotos.genimage | size: 0:0:0:300 | rotate: 90}${/}
Thank you
ZenMasterZeke
Would the 'if' go in the variable name? Only done minor stuff in reports, but that seems wonky based on what I know about attributes in reports (not much).
Neal_t_k
AlfredBaldenweck
Thanks for the responses, guys.
I have an ${/} at the end. It gives a different error when that is the problem.
if is also supposed to be in there
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-conditionalelements.htm
I agree that the formatting is wonky. The lack of an Else option, for one thing...
Reviewing the documentation again, I bet it's that i need to wrap each value in a parenthesis. I'll report back later
AlfredBaldenweck
Correct syntax:
Thank you
