I've set up I repeating section that includes a select_one or_other option. When I choose the 'other' option all the previous fields in the repeat section get truncate with the 'other' option values.
Here is the code I'm using:
Any suggestions?
Well, it is that time of year again and I'm having an issue with the or_other option for select_multiple and Report(Beta). When I choose multiple options from the select list and the other option the text input into the Specify other. dialogue box gets repeated multiple times in the Report word doc.
Results in:
Field Technician: | ${FieldTech} |
Field Technician: | Mark L , Jimmy , Aldrin P , Jimmy , Jimmy |
Any suggestions?
Adam
Hi Adam,
It looks like you are encountering BUG-000122052 and this issue is resolved in 3.5 release.
I did author the form on Connect v3.5.152.
Hi Adam,
The fix is on the Survey123 website, the 3.5 version will be released next Thursday. Please check the issue again on the Survey123 website.
Thanks for your help. I was using the early adopter versions, looking forward to the full release next week.
