Repeats not being hidden in Survey123 report
578
08-12-2021 11:36 AM
IanGallo
I am trying to have the folowing repeats hide/appear based on whether or not there is a record present (gm_lifestages_table, nr40_table, and reg_action_table). I cannot get them to reliably behave as expected despite using the attached syntax. Template and xls form are attached. Any help would be greatly appreciated!
abureaux
MVP Regular Contributor
In the template, your nr40_table is using the expression ${if (nr40_table | getValue:"count")>=0}. That may be a part of it.
What you are doing is very similar to what I was doing. I am surprised that you can actually parse this document successfully. After the recent update by esri, all my getValue:"count" for repeats were failing parsing. What I did was add Calculate fields inside my XLS to count the repeats, then I referenced those calculate fields inside the DOC.
Old
New
Representative${if (site_rep_repeat | getValue:”count”)>1}s${/}Representative${if site_rep_repeat_sum>1}s${/}
Otherwise, you set-up looks good.
