Hi ,
Is there or should there be functionality in the webhook to use HTTP get a file in integromat to download photos from a survey that are from a repeat or multiline question? At the moment we can only download a single image from a multiline question.
Cheers
Thanks for that. That helps a lot. You mentioned that you were able to insert the pictures into the excel doc? Is it possible for you to share the flow involving that?
Thanks!
