Repeat count showing as 1 when no record is created
290
03-28-2024 07:08 AM
ChristopherDawe
New Contributor III
I am having an issue with a repeat count in my survey where the default value is 1 even when no record is created.
the survey is a nested repeat, both main repeat and nested repeat appearances are set to minimal compact so you have to press the "+" button to create a record.
For the main repeat table I have a field outside the repeat with  count (${mainRepeat}) in the calculation column which is behaving as expected, the value is 0 until you press the "+" to create the first record in the repeat at which point it becomes 1, and grows with the number of repeats added.
For the nested repeat I have  a field outside it (but within the main repeat) with count(${nestedRepeat}) in the calculation but this shows as 1 even when there is no initial record created in the repeat (see below). Once records are created it behaves as expected, however in some instances I may not require any records and would like the count to show as 0
I have read that there are issues with this where calculations are involved inside the repeats but it works on the main repeat so a bit baffled as to why it behaves differently on a nested repeat.
For a workaround I have used a count of the geopoint question in the nested repeat which is ok in this instance as it is a required question so will always count correctly, however relying on this method may not always work depending on whether questions are required or not
Any ideas would be welcomed
DougBrowning
MVP Esteemed Contributor
I wonder if it is similar to this issue?
https://community.esri.com/t5/arcgis-survey123-questions/once-join-work-differently-on-the-first-rep...
Like you I always count a field that has to be filled out in the repeat and it seems to work better.
Sometimes I have used the relevant on the begin repeat line but I cannot exactly remember what that was doing.
