Where can we rename a Survey123 template? I download the RoadKill template for Survey123 and changed the items but I cannot find where to change the name of the template "RoadKill Report"?
Thanks!
Solved! Go to Solution.
Hi Warren
Open the XLSForm spreadsheet, go to the settings table and under the form_title column rename to your required form title.
Cheers
Chris
Hi Warren
Cheers
Chris
Chris Roberts Might you consider writing a Blog Post in GeoNet explaining the differences in the naming of survey forms and published surveys in Survey123? I find it very confusing.
Here's what I think I know:
Thank you,
Joe
Thanks Joe- very helpful. I'd like to see a blog post too. If you download a template and want to rename it, apparently you have to make all the changes Joe suggests above, and you still end up with all the files in the C:\Users\<name>\ArcGIS\My Survey Designs folder having the template's name.
Dake
You also have to change name of the following files:
*.gpkg
*.info
*.itemInfo
*.xlsx
*.xml
Edit forminfo.json in a text editor and change the "name" tag
